| Tech by Androda Products |
MICHAENTOSH New Tinkerer -------- Joined: Oct 28, 2021 Posts: 11 Likes: 11 |
Dec 8, 2023 - #21
HERE IS THE MOTHERBOARD, NO VISIBLE LEAKAGE BUT SOMETHING IS GOING ON HERE WITH THIS WIRE?
Dec 8, 2023 - #22
Probably best to break these posts out into their own diagnostic thread rather than clutter this one.
Liked by eric |
Androda TinkerDifferent Board Secretary 2023 USA, Western -------- Joined: Sep 25, 2021 Posts: 523 Likes: 581 |
Dec 8, 2023 - #23
Based on the picture, those are the original capacitors. Even if they did not visibly create a pool of fluid on the motherboard, they can fail invisibly or cause corrosion directly underneath the little black plastic pad they sit on (I've seen the latter, looks perfectly clean but failed and corroded underneath). As stated a few times in another thread about the Mac Portable, the original capacitors must be replaced for reliable system operation. Liked by wottle |
Dec 12, 2023 - #24
New product: The HD68 to Desktop 50 Adapter. Plugs straight into a BlueSCSI or other 50 pin internal Desktop drive and connects to the HD68 bus. Includes a high-byte terminator for situations where that matters.
Low stock availability, these connectors are expensive and I don't want to order a ton of them if there's not much interest. Crappy product photo is below:
Dec 12, 2023 - #25
I presume this would be merely adapting the 16-bit bus to an 8-bit device?
Dec 13, 2023 - #26
Dec 13, 2023 - #27
Hot on the heels of the HD68 to 50 adapter is this HD50 to 50 adapter. Super low stock availability, these connectors are a mess to get ahold of.
Also, the Mac Portable to BlueSCSI adapter is now restocked including for 2023_10a.
wottle Active Tinkerer Fort Mill, SC -------- Joined: Oct 30, 2021 Posts: 841 Likes: 577 |
Jan 1, 2024 - #28
FYI, I finally got around to assembling and installing the battery eliminator in my backlight upgraded M5120 and can confirm it works well. I have the 7MB upgrade and the replacement hybrid card. No issues running it today after giving the caps time to charge up.
Liked by Androda |
Garrett Tinkerer South Carolina -------- Joined: Oct 31, 2021 Posts: 144 Likes: 139 |
Jan 10, 2024 - #29
Jan 15, 2024 - #30
Liked by Garrett |
Jan 18, 2024 - #31
Announcing the first entry in the HIDHopper(tm) adapter series, HIDHopper(tm) ADB.
This adapter allows you to use modern USB keyboards and mice on your Mac that needs ADB. Has been tested across a few generations of Macs, including the Portable, PB 180, Quadra 700, and some later PowerMacs. HIDHopper(tm) ADB - Tech by Androda
[Image: androda.work]
androda.work
Liked by MrBIOS,Byte Knight,splorpand 3 others |
Jan 22, 2024 - #32
Surprisingly, several people have messaged me recently asking for recreation cables of the Mac Portable M5120 Backlight Upgrade. I didn't think enough of them survived for it to make sense to have a product listing on my site, but here we are.
This is not for the M5126 Backlit Portable, it's a recreation of the backlight upgrade flex cable for original M5120.
Liked by wottle |
Jan 22, 2024 - #33
Liked by Androda |
Jan 25, 2024 - #34
BlueSCSI design update:
The DB25 model went to the gym and lost some weight, now the PCB is only as wide as the DB25 connector. This should help situations like the IIci where SCSI is right next to the display port (wide connector next to a wide adapter). The previous DB25 Mini will be phased out in favor of this new slimmer style.
Liked by wottle |
endsjustify New Tinkerer -------- Joined: Feb 8, 2022 Posts: 4 Likes: 2 |
Feb 2, 2024 - #35
Hey for this item: https://androda.work/product/newton-internal-serial-for-2000-2100/
When I download and copy the Internal Device Prefs.pkg from my modern Mac to my LC 575 for installation over the Newton Connection Utility, the NCU cannot see the .pkg as an installable item when connected to my Newton. I simply cannot select it for install as it won't appear in the list. I think the modern Mac is somehow altering the .pkg thinking it is modern Mac install .pkg in some way. Are you aware of an issue there, or is it possible to get this file compressed as a .sit so I can decompress it directly on the LC575 and not have the modern Mac touch the actual .pkg itself? EDIT: NM, sorted it with Mac PKG fixer. Cheers! |
Feb 3, 2024 - #36
Could you post a link to the Mac PKG fixer tool for future use? |
Feb 3, 2024 - #37
United Network of Newton Archives
[Image: www.unna.org]
www.unna.org
Liked by Androda |
splorp Tinkerer Calgary, Alberta -------- Joined: Oct 31, 2021 Posts: 170 Likes: 154 |
Feb 3, 2024 - #38
More information from the Newton FAQ:
Why won't the package installer recognize a .pkg file? http://newtonfaq.com/newton-faq-nos.html#IIIC3 |
Feb 23, 2024 - #39
The Mac Portable Adapter for BlueSCSI V2 is getting an update. You no longer will need to select a BlueSCSI hardware version because the bracket is universal for all Desktop models, old and new. Brackets are printing now, will update the listing once they are done.
Mar 26, 2024 - #40
Stock counts are low on the Mac Portable VGA adapter, but more will be on the way soon.
This product does what it says: Mac Portable digital video out port -> 640x480 VGA. Doesn't convert the other way, sorry.
Liked by JustG,JDWanderic |
| << First | < Prev | Page 2 of 3 | Next > | Last >> |
