Comm Slot II 10/100 Ethernet Cards
Aug 1, 2024 - #41
Fabulous achievement, props! :cool:
Fizzbinn
Charlottesville, VA
Aug 6, 2024 - #42
Results!
Your new card certainly holds its own against the other 100Mb PCI cards! Certainly faster then the regular Apple CS II card!
Reminder on the test environment from a few posts back, these tests were from/to my Raspberry Pi 4 "retro home server" running MacIPRpi (1Gbps Ethernet) with both the PM 6500/275 and the Pi connected via an Apple Airport Extreme 6th Generation's Gigabit capable Ethernet ports. The software used was Newer Tech "Performance" v1.3 which is included in their EtherTech 1.5 installer.
1722913922283.png [View]
Liked by Androda,eric,Kai Robinsonand 1 other person
Fizzbinn
Charlottesville, VA
Aug 7, 2024 - #43
@Androda Is it correct to assume that the Farallon 993v14 driver would work with any PCI Ethernet card based on the RTL8139? There aren't any vendor/manufacture checks, something like MAC OUI ranges?
I was curious about your 3D printed "mounting tang", didn't know conductive plastic was a thing. I had wondered if I might be able to swap in the metal mounting tang from one of the CS or CS II modems I have but the jack knock outs are not wide enough. The one you made you made seems to be more than good enough though.
Mac84
New Jersey, USA
Aug 7, 2024 - #44
This is an excellent card, I tested it in my Power Mac 4400 and it worked great under System 7.5.3, 7.6.1 and 8.1
Overall, the card is very zippy. I copied a 150MB file over an Ethernet AppleTalk network (from a Mac mini G4) in just a hair under 3 minutes.
File downloads using a web browser seem to be maxing out at around 220 KB/sec (at least against my web sever). These speeds were consistent across all the operating system versions I tried. Highly recommended! (y)
Liked by Fizzbinnanderic
Androda
USA, Western
Aug 8, 2024 - #45
>> Fizzbinn said:
@Androda Is it correct to assume that the Farallon 993v14 driver would work with any PCI Ethernet card based on the RTL8139? There aren't any vendor/manufacture checks, something like MAC OUI ranges? Click to expand...
It's possible, but I don't really know. Tried some random MAC addresses during testing and not all of them worked. That's part of the reason there are three: those ones worked properly.
>> Fizzbinn said:
didn't know conductive plastic was a thing Click to expand...
Yeah it's pretty funky stuff. Doesn't print amazingly well, but still "good enough."
Liked by Fizzbinn
Fizzbinn
Charlottesville, VA
Aug 8, 2024 - #46
>> Androda said:
It's possible, but I don't really know. Tried some random MAC addresses during testing and not all of them worked. That's part of the reason there are three: those ones worked properly. Click to expand...
The MAC address OUI prefix (00:00:C5) on the card I got from you appears to match what Farallon was using for their real PN993 NetLINE 10/100 cards:
FARALLON PN993 8970887-00-03 10/100 PCI Chip Realtek RTL8139C w/ CD | eBay
Find many great new & used options and get the best deals for FARALLON PN993 8970887-00-03 10/100 PCI Chip Realtek RTL8139C w/ CD at the best online prices at eBay! Free shipping for many products!
www.ebay.com
That OUI prefix is now registered to "ARRIS Group, Inc." which I'm guessing is where Farallon's stuff ended up after 20 years of mergers and acquisitions.
Curious, were the MAC addresses you tried that didn't work from a different MAC address OUI prefix?
www.ebay.com [View]
Fizzbinn
Charlottesville, VA
Aug 31, 2024 - #47
>> Fizzbinn said:
The MAC address OUI prefix (00:00:C5) on the card I got from you appears to match what Farallon was using for their real PN993 NetLINE 10/100 cards: FARALLON PN993 8970887-00-03 10/100 PCI Chip Realtek RTL8139C w/ CD | eBay Find many great new & used options and get the best deals for FARALLON PN993 8970887-00-03 10/100 PCI Chip Realtek RTL8139C w/ CD at the best online prices at eBay! Free shipping for many products! www.ebay.com That OUI prefix is now registered to "ARRIS Group, Inc." which I'm guessing is where Farallon's stuff ended up after 20 years of mergers and acquisitions. Curious, were the MAC addresses you tried that didn't work from a different MAC address OUI prefix? Click to expand...
I ended up buying one of those Farallon PN993 NetLINE 10/100 PCI cards just because. Perhaps unsurprisingly it seems to perform the same as @Androda's card.
www.ebay.com [View]
<< First | < Prev | Page 3 of 3
