| Tiger OSX - OS9 not recognized as startup volume |
Forums > Vintage Apple > Software & Operating Systems > Software | Mac OS (PowerPC)
Bolkonskij Tinkerer Bavaria (near Germany) -------- Joined: Nov 15, 2021 Posts: 58 Likes: 32 |
Oct 9, 2023 - #1
Hi folks,
I have a Mac Mini G4 that dual-boots OSX Tiger ("Shuriken") and Mac OS 9.2.2, each on their own partition. The OSX Startup Volume control panel doesn't recognize the OS9 installation as bootable, giving me only the OSX partition as an option. It *does* recognize the OS9 partition in general though (e.g. mounts it on the Desktop, shows in Disk Utility, etc.) OS 9.2 works perfectly fine on the Mac, no troubles when booting via holding the option key on startup. Does anyone know why OSX refuses to recognize the OS9 partition as bootable in the startup volume panel and how to fix that? Not much of a OSX guy here ... appreciate any help! |
Paolo B Tinkerer Switzerland -------- Joined: Nov 27, 2021 Posts: 303 Likes: 182 |
Oct 9, 2023 - #2
Had the same issue some time ago with my Cube G4, if I remember well you need 9.2.1 or something like that...
Liked by eric |
robin-fo Tinkerer Switzerland -------- Joined: Feb 17, 2022 Posts: 157 Likes: 76 |
Oct 9, 2023 - #3
Don't forget that the Mac mini officially doesn't support Mac OS 9...
Oct 10, 2023 - #4
Did you install the OS 9 disk drivers when you partitioned it?
Oct 10, 2023 - #5
Yes, I did. Would OS9 work if I hadn't? I don't think so?
And it does work fine. Everything works. Except OSX detecting it as bootable. Funny thing: It DOES show up as a valid OS9 installation to boot from in Tiger's Classic Mode? |
scj312 Tinkerer -------- Joined: Oct 29, 2021 Posts: 74 Likes: 87 |
Oct 15, 2023 - #6
Mac OS X hides OS 9 from Startup Disk if the machine's "compatible" property in Open Firmware is set to "MacRISC3" (which it is set to on all machines that are "X only.") Presumably this is to prevent confusion after installing a system folder for Classic.
You can change the "compatible" property in Open Firmware to "MacRISC2" and that will cause Startup Disk to show OS 9 again. Here's a bootscript that does just this on my "X only" iMac G4, allowing me to select OS 9 from Startup Disk (it also lets me boot "unsupported" versions of OS X, such as 10.0 and 10.1.)
(note, this takes effect for only one "boot". You will also need to change the partition ID on the last line for the partition to boot.) Liked by Certificate of Excellence |
