Surface finish on 3D-prints?
mmu_man
Feb 25, 2023 - #1
I'm wondering what others use as surface finish on their prints, do you leave it as-is, do you use smoothing sprays (haven't tried yet)?
I experimented a bit with sanding (here on the bottom part on the right one, but I find it too matte compared to the LC case), then hot air + pushing against sand paper (top part), but it's not very conclusive.
Mac_LCSD_DSCN2409.jpg [View]
mmu_man
Mar 4, 2023 - #2
I found an interesting technique which gives good results for flat surfaces, and more work for the rest...
[Image: Mac_LCSD_DSCN2446.jpg]
The small version here has a curve in the middle of the front face which doesn't help... These units received several tests though...
[Image: Mac_LCSD_DSCN2441.jpg]
Other options I haven't tried: painting, glossy or matte smoothing spray... Do you know other options?
See the thread on Mastodon.
Mac_LCSD_DSCN2446.jpg [View]
Mac_LCSD_DSCN2441.jpg [View]
