| Sun SPARCstation 1+ help needed (SOLVED) |
Forums > Vintage Workstations > Sun Microsystems
The House of Moth Tinkerer Ohio, USA -------- Joined: Oct 18, 2021 Posts: 108 Likes: 225 |
Oct 19, 2021 - #1
I found two of these machines. Think I don't know beige Macs? I know Sun even less!
Doesn't look like I can just hook up a VGA display and USB keyboard to it so.... help! What do I need to test these?
mastanhope New Tinkerer Marysville, PA -------- Joined: Oct 19, 2021 Posts: 4 Likes: 7 |
Oct 19, 2021 - #2
You will need a propritary SUN keyboard and mouse for them, a 12W3 video adapter to hook a display up, and alot of patience. They do use a SCSI hard drive, but many SUN machines will not boot if the backup battery (PRAM battery) is dead and does not save settings. There is alot of basic information here https://en.wikipedia.org/wiki/SPARCstation_1
Liked by The House of Moth |
ScutBoy Administrator Northfield, MN USA -------- Joined: Sep 2, 2021 Posts: 356 Likes: 342 |
Oct 19, 2021 - #3
Both Sun keyboards/mice and the 13W3 adapters to VGA can be found on eBay. Or I can send you a keyboard/mouse - I have plenty!
Not handy to me now, but if you search for the Sun NVRAM FAQ it will tell you more about what you need to do to fix that problem. And, if you want to sell or trade for one of those guys, a Sparc 1 is something I'm missing in my collection. :) |
Oct 19, 2021 - #4
Here is the NVRAM FAQ:
Glitchworks makes a nice little replacement board that lets you use a coin cell battery. You need some Dremel and soldering skills, but it's a nice long-term replacement. I've done about a dozen of these over time... GW-48T02-1, a Module for Rebuilding the 48T02 RTC/NVRAMWith a large number of vintage Sun machines in the shop, I was stuck with having to repair or replace dead batteries in the 48T02 RTC/NVRAM modules used on many early SPARC systems. Modern replacements are not 100% compatible, so the old modules have to be repaired. There are clearance issues in...
www.glitchwrks.com
I'm pretty sure the Sparc 1 is the 48t02, but if it's the 48t08, he has the board for that, too. If he's out of the boards, I could probably spare one or two... the other parts are available on Mouser/Digikey very reasonably. |
Oct 19, 2021 - #5
Oct 24, 2021 - #6
It appears these Sparcstations are no longer my problem :) Case closed!
Oct 24, 2021 - #7
Glad I could help :)
