| SSD in an TAM (ATA Drivers Issue) |
Silver04GT New Tinkerer -------- Joined: Jun 18, 2023 Posts: 2 Likes: 0 |
Jun 18, 2023 - #1
Hi everyone, I've been on a long journey trying to get my TAM to boot from 120GB SSD, I'm booting to a Mac OS 9.1 install CD to do the installs.
The parts I'm currently using are: Dogfish Msata 120GB Internal Solid State Drive Mini Sata SSD Disk GINTOOYUN MSATA Mini PCI-E SSD to 2.5 Inch IDE 44Pin Enclosure Adapter I've also tried: Ableconn IIDE-MSAT mSATA SSD to 2.5-Inch IDE Adapter Converter with Aluminum Frame Bracket GODSHARK Laptop SATA to IDE Adapter, Convert 2.5 Inch Serial ATA HDD Hard Disk Drive or SSD to 44 Pin Male PATA Port Kingston 120GB A400 SATA 3 2.5" Internal SSD SA400S37/120G Transcend 128GB SATA III 6GB/S MSA230S mSATA SSD 230S Solid State Drive For software I've used: Drive Setup from Mac OS 9.1 install disc FWB Hard Disk Toolkit SilverLight The Gintooyun adapter seems to be the best at actually showing hard drives, I've various level of success with the Transcend and Dogfish drives. It seems like when they are fresh of out of the package some about the initial format of the drive things work as expected, but if you ever reformat the drive things go south. I did have a working config yesterday and the ATA driver showed v2.0a8 but I never seem to be able to get it back to that version now that I messed it up. I know that SilverLight installs an ATA drive that's version 6.1. When I try to install with that driver I get a lot of weird distortions of the icon on the desktop and even file names get weird random characters in them. Anyone have any suggestions or ideas on either how to get back to that specific ATA driver version or what else to try? Thanks!
misterg33 New Tinkerer -------- Joined: Oct 10, 2022 Posts: 61 Likes: 14 |
Jun 20, 2023 - #2
Have you tried one of the SD Card or CF Card to ATA adapters instead? Considering the age of the machine, I doubt using an actual SSD will seem much faster. Also is there anything plugged into the PCI slot?
Jun 20, 2023 - #3
I decided to try and order the KingSpec PATA SSD in 64GB. I'll give that a try and if that fails I'll try the CF route. |
bakkus Moderator -------- Joined: Mar 18, 2022 Posts: 110 Likes: 75 |
Jun 20, 2023 - #4
There's also the route of @dosdude1 making new IDE SSDs. You can hit him up for pricing/orders.
ried New Tinkerer -------- Joined: Jan 23, 2022 Posts: 8 Likes: 9 |
Jul 24, 2023 - #5
I've purchased these for both of my TAMs and they work flawlessly:
32GB Transcend PSD330 2.5-inch IDE Internal SSD Solid State Disk (MLC Flash) Hope it helps. |
[Print View] |
