| Snow EMU - Emulator for 680x0-based Macintosh computers |
eric Administrator MN -------- Joined: Sep 2, 2021 Posts: 1,149 Likes: 1,926 |
Aug 13, 2025 - #1
Snow | Classic Macintosh emulatorClassic Macintosh emulator - About
[Image: snowemu.com]
snowemu.com
Snow emulates classic (Motorola 680x0-based) Macintosh computers. It features a graphical user interface to operate the emulated machine and provides extensive debugging capabilities. The aim of this project is to emulate the Macintosh on a hardware-level as much as possible, as opposed to emulators that patch the ROM or intercept system calls. It currently emulates the Macintosh 128K, Macintosh 512K, Macintosh Plus, Macintosh SE, Macintosh Classic and Macintosh II. The emulator is written in Rust and released as open source, licensed under the MIT license. To get set up or for further information, check the online documentation. Download
Liked by ScutBoy,and.short,wottleand 3 others |
Aug 13, 2025 - #2
FWIW this has replaced mini-vmac for almost everything I do with emulators locally. It's very new so lots of features are being added quickly and you might run into the occasional bug.
Emulate a Mac 128k up to a Mac II with 128MB of RAM. '020 is the max 68k supported currently. Liked by JDW |
JDW Administrator Japan -------- Joined: Sep 2, 2021 Posts: 2,534 Likes: 1,981 |
Aug 14, 2025 - #3
Thank you for this announcement, @eric !
I see from the FAQ that the emulator is called "SNOW" because of the "Snow White" design language Apple used (via Frog Design), starting with the Apple IIc in 1984 and continuing in the Macintosh line until the IIfx in 1990. "Snow White" is a little confusing because some conflate the "design language" with COLOR. Indeed, the Apple IIc was truly "Snow White," not only in terms of its design but in color too. Earlier Apple II machines were beige, and so were the first Macs. The Mac Plus started out as beige, but the plastics later changed to Platinum color. Even so, Macs were never Snow White in color. Macs were only Snow White in terms of their "design language." The Mac Classic, LC, and IIsi were among the first Macs which did not use Snow White fully. And the Quadra 700/900 (1991) & Quadra 950 (1992) are similarly Neo Snow White, carrying over some design elements but not all. The 1993 Color Classic is an example of a machine with a clear departure from Snow White, instead using a "neoclassic" industrial design. The website says Snow currently emulates these Macs:
This new emulator should be interesting to tinker with because it is a departure from Mini vMac in that it strives to do a more perfect emulation of the actual hardware, which is neat. And it's great that Disk Jockey 4 makes it easier to convert disk images, since the images for Mini vMac need to be modified before use. Liked by akator,fehervariaandslomacuser |
Sep 5, 2025 - #4
Snow has reached 1.0 https://github.com/twvd/snow/releases
Notable feature for users is the ability to select a set of files and it will create a iso on the fly and mount it to transfer files into a emulated mac. -- After VCF-MW I'll finish up and add BlueSCSI emulation into Snow. Think "ImportFi/ExportFi" in minivmac. It currently all works, but I've got a lot to clean up.
Liked by Scorpio_ny,bakkus,Nitram78and 5 others |
joethezombie Tinkerer Idaho -------- Joined: Oct 30, 2021 Posts: 34 Likes: 31 |
Sep 5, 2025 - #5
This is awesome!
Sep 22, 2025 - #6
SnowEMU v1.1.0
Liked by andrew,Nitram78andJDW |
slomacuser Tinkerer -------- Joined: Nov 1, 2021 Posts: 142 Likes: 138 |
Sep 26, 2025 - #7
Some suggestions:
On Windows I would prefer Left ALT as a command key and supporting the international keyboards, I have to be careful when using QWERTY or QWERTZ. And maybe that you do not have to load Workspace setting every time :) Liked by JDW |
Sep 26, 2025 - #8
Also got some crash
Sep 26, 2025 - #9
@slomacuser Please report these on the projects github issues so the maintainer can see them. I'm just an occasional contributor and cheer leader of the project :)
Sep 27, 2025 - #10
And done: https://github.com/twvd/snow/pull/134
Liked by Scorpio_ny,akator,joethezombieand 3 others |
Nov 7, 2025 - #11
twvd just merged in Portrait Display support - so those of us who will never find/afford a Portrait Display can still experience it!
Liked by JDW,akator,ClassicHasClassand 4 others |
mmu_man Tinkerer -------- Joined: Jan 30, 2022 Posts: 187 Likes: 125 |
Nov 11, 2025 - #12
So powerful it even emulates an Atari \o/
... Kidding, that's my EmuTOS port to Apple just starting up. Not fond of having to download half of Internet, but I guess that's half less with Rust than with Node... At least now i have an emulator that works (couldn't get it to run on BasiliskII or QEMU).
Liked by thecloudandClassicHasClass |
Dec 8, 2025 - #13
I've added Serial port emulation for Linux/Mac (windows users sorry, someone else is going to have to add it, i dont have windows anymore)
So we can do cool things like, get online via PPP: Or use Retro68's LaunchAPPL to directly send and launch apps you compile on a modern computer to a retro emulator: Snow is fast becoming the most full featured, easy to use, Macintosh emulator.
Liked by thecloud,akator,RickLawsonand 4 others |
Byte Knight Tinkerer -------- Joined: Oct 21, 2021 Posts: 133 Likes: 116 |
Dec 9, 2025 - #14
akator New Tinkerer -------- Joined: Aug 25, 2023 Posts: 30 Likes: 11 |
Dec 10, 2025 - #15
The work on Snow is very impressive. Are there any plans to add 68030 and 68040 emulation?
Dec 10, 2025 - #16
Liked by JDWandakator |
Dec 10, 2025 - #17
EDIT: Just noticed the Github Read Me mentions SE/30, IIcx, and IIci. Yay! |
fourteentones14 New Tinkerer -------- Joined: Oct 6, 2022 Posts: 13 Likes: 7 |
Dec 11, 2025 - #18
I thee there is a PR for LToUDP, this is so cool, I use it with my "wifi" PowerBook 100 + minivmac to sync files on my modern computer, can't wait to test it in Snow too!
Dec 11, 2025 - #19
Dec 11, 2025 - #20
I made a small board with an esp32 + tashtalk, which fits in the modem port and runs an 'integrated' airtalk, so I can bridge it directly to minivmac.
| Page 1 of 2 | Next > | Last >> |
