| SE repair...power supply questions |
T-Man Tinkerer -------- Joined: Oct 30, 2021 Posts: 55 Likes: 37 |
Dec 26, 2025 - #1
My SE recently just crashed, no screen, no noises, no bong, no disk drive. I thought power supply and wanted to get inside to look at the boards anyway so just thought I'd remove the power supply to check directly. The Sony Model CR-44 power supply has a sticker on the side with pins and voltages listed, so, GREAT pins and voltages! However, measured the voltages and got 5.35 on the 5-volt pins, 13.86 on the 12 volt and -8.5 V on the -12 volt.
So, its unloaded and after searching found that the 12 volt and 5-volt lines are probably correct unloaded. I have enough respect for the CRT that I'd really rather not assemble and plug in to adjust while the CRT is exposed. Regardless, is the -8.5 V on the unloaded Sony Model CR-44 power supply the problem? Will the voltage actually go up on the negative rail when loaded? If it is the -12 volt, should I still be getting a start-up chime? |
Saturday at 11:29 AM - #2
It was the analog board...not the power supply.
Liked by GreenBar0n |
GreenBar0n New Tinkerer East Bay Area, CA -------- Joined: Dec 22, 2025 Posts: 32 Likes: 6 |
Saturday at 9:58 PM - #3
You were able to fix the problem, or you just found the problem so far?
Saturday at 11:55 PM - #4
Took another SE apart, the problem is on the analog board.....I'm guessing fly back as I hear a very quiet clicking
Sunday at 1:37 AM - #5
It's pretty much vital to have multiple units to test with, it would seem, in order to determine quickly what the issue could be.
Is the bad fly-back covered in black soot, like it was heavily used over the years? |
Sunday at 2:05 AM - #6
It didn't look bad. Will have another look at some point, was just determined to get an accelerator board working so sacrificing one SE ok for now.
