| SE/30 noise in video - where do I look next? |
basslinemz New Tinkerer -------- Joined: Nov 16, 2025 Posts: 3 Likes: 0 |
Nov 18, 2025 - #1
I'm new to this forum, and fairly new to some aspects of vintage computer repair even though I've used 'em since they weren't vintage. I've dug through these forums and others but not seen an issue quite like the one I'm dealing with.
I've got an SE/30 that, until this past year, I didn't even know worked - I was given it along with several other partial compact Macs by a friend years ago, and they sat in a shed that wasn't terribly watertight, so when I dug them out for a project, there was plenty of surface rust, and the mainboard was a bit crusty looking, but fortunately not battery bombed. After a reasonable cleaning, and wiggling the ROM SIMM a bit, it came to life, and it's got an external video card in it, even! In the process of making it more presentable, I've swapped the analog board for a spare from an SE that had a good flyback transformer, recapped THAT board, the power supply and the mainboard with kits from Console5, put a new battery in and replaced the HDD (which I managed to get working enough to back up) with a BlueSCSI. It now boots (and chimes) and runs reliably, and for the most part, looks great. Except there's noise in the video that gets stronger as it warms up - after about ten minutes, it reaches a peak and stays there. I saw it surge with HDD activity while I was working on recovering the files that came with it, but that part isn't in the machine. I've tried replacing the HOT and reflowed the analog and CRT boards, but am unsure where to look next. The caps on the mainboard leaked at least a little, at least judging by how they looked when I removed the old ones, but I don't see much of anything that looks like corrosion beyond all the solder on the board being dull and slightly soft (fuzzy?) looking - no green crud. All of the pads came clean easily and everything looked good to my eyes otherwise. I swapped the CRT board with the one from the SE, and the noise changed a bit but didn't go away. The only consistent thing I can to to reduce the noise is to turn down the brightness - the brighter it is, the stronger the noise is. The pictures attached show this at normal brightness (the noise moves randomly like static) and one turned almost to nothing, edited to be more visible. I also haven't seen any rogue solder or bridged connections, though it's always possible that I missed one. Would the CRT board be the next thing to investigate, or should I still be looking at the motherboard or somewhere else? I've always been good to hang parts, and now I feel more confident I can solder them, but circuit-level diagnosis is still kinda new to me.
ArjenCNX Tinkerer -------- Joined: Oct 20, 2025 Posts: 63 Likes: 55 |
Nov 28, 2025 - #21
Yeah ripple current and ESR matter allot for what we do :) must have for any of us nerds is a LCR meter for testing the boogers !
Liked by muse |
JDW Administrator Japan -------- Joined: Sep 2, 2021 Posts: 2,534 Likes: 1,982 |
Nov 28, 2025 - #22
In regards to good quality LCR meters, unless you're going to pay more than $1,000 for a benchtop meter, the absolute cream of the crop for hand-held in a reasonable price range is the DE-5000, which I personally use all the time:
I first learned about it some years ago on the EEVBlog forum. A lot of people use it. It's pretty great. With that said, I've had caps which were old, never leaked, and measured good, yet they failed in-circuit. So the meter can be a useful guide, but it's not a perfect solution for finding bad caps all the time. Liked by muse |
muse Tinkerer Oz -------- Joined: Nov 3, 2025 Posts: 41 Likes: 30 |
Nov 28, 2025 - #23
I did initially order the wrong sized capacitors on the primary side for the Sony PSU.. whoops, they wouldn't fit. If only I had looked at the cap list that you had posted online for the various components before ordering. |
Nov 28, 2025 - #24
For a single project one-off, Console5 is cheap. It's hard to beat it. But yes, buying several recap jobs' worth of parts at once from Mouser or DigiKey to get free shipping can work and get you low prices too. You just need to watch out when using SMD types like Polymer Tantalum because they have to be installed within a certain amount of time, as I describe at 15:10 here:
Liked by muse |
Nov 28, 2025 - #25
Dec 15, 2025 - #26
I can't say for certain if I noticed the issue before the recap work, as I was mostly trying to get the external video card working reliably. I recall a noisy display at one point, but that was with the original analog board shortly before the flyback audibly crapped out and I switched to the one that's in it now (also the one that was cleaned and recapped). And yes, I recognize that this situation is novel - that's why I created an account to ask questions here, hoping someone had a lead I could follow because the Googles, they had nothing. I wish I had more to tell you - I know it's isolated to the horizontal plane, it starts out very weak when cold and increases as it reaches full temperature, it's not affected by replacing the CRT or the CRT board, and that a questionably functional HDD connected to the device can make the same kind of noise appear when there's disk activity. (classroom pic attached because why not?)
| << First | < Prev | Page 2 of 2 |
