REVIEW of Mockingboard 4c for Apple IIc
Jan 1, 2025 - #1
My first Apple II was acquired in October 2023. Being a Mac guy since 1984, I was accustomed to "good audio." There was nothing about any Macintosh I ever used that made me think, "Wow, this audio is bad!" But when I first tested the IIc with music and gaming apps, I was really quite shocked at how awful the audio was. To be fair, the IIc was based on tech that came out in 1977, and Steve Wozniak only intended the speaker for simple beeps and clicks. The Mac came 7 years later, with many advances. Even so, good sound is good sound no matter when a sound making device came on the scene.
So it was a pleasant surprise when I learned about the Mockingboard in 2023 and the fact that a modern creation was able to fit the board INSIDE the IIc, retaining its compact form factor. I finally got around to reviewing the kit, and I must say that, despite the caveats, it really makes a noticeable difference. Not every app is Mockingboard aware, but for those which are, your ears will thank you for having added it.
One of the first things I show in the video is the Sweet Micro History segment. I found an article in SOFTALK magazine on Internet Archive, and I spent a lot of time slimming down the content in order to build a text timeline. Sadly, that was really the best and only source for the history I had available. But knowing it's really best to reconfirm such info, I reached out to Sweet Micro Founder, Rod Nakamoto, who created the first Mockingboard product in the late 70's. Many times when you try to contact a "famous name" in computing history, no reply comes. But I was overjoyed that Mr. Nakamoto replied back a day later with corrections and new info, found no where else, such as Woz having purchased 100 Mockingboards to give as gifts to his friends.
Rod unfortunately didn't have any photos from back in the day, so I improvised. I used some photo content from the SOFTALK article and with AI I was able to improve the look. I then used a Manga edition AI to generate some artwork that in the end fit well into the timeline. I think the end result came out halfway decent.
Work on this video began more than two months ago. It was shocking how many hours I invested in it. But the end result is a comprehensive look at the Mockingboard, both past and present, will a full installation segment, testing and an overview of the Good and the Bad. Be sure to check out the TEXT DESCRIPTION under the video on YouTube because I have a lot of links there, including a link to my software compatibility list.
I also learned a few new things after the video was finished, such as the fact that the MacEffects backlit keyboard's backlight has an impact on audible noise. But that is a subject for another video.
Happy New Year 2025 to one and all! I hope this video will inspire some of you to pull those Apple II machines from the closet in 2025 and put them to good use.
Liked by MacEffects,nottomhanks,wottleand 4 others
chrisrueckert
Jan 4, 2025 - #2
Thanks for this great review and video. I'm so sorry for the broken tabs of the case! Hopefully, others won't go through the same terrible experience.
Jan 4, 2025 - #3
>> chrisrueckert said:
I'm so sorry for the broken tabs of the case! Hopefully, others won't go through the same terrible experience. Click to expand...
The upside is that I broke my tabs so other people don't have to! :) Naturally, I didn't do it on purpose. I really was given bad advice. I don't see how some people contend that drop-to-open works on that MacEffects case. It didn't for me, obviously. But it does work fine on the stock case, at least the 2pc case (not the one with a separate back panel).
By the way, I am still working on my MB4c Compatibility List, which you can check out here:
Mockingboard 4c Compatible Software
GAMES -- Mockingboard Compatible 8bit-Slicks††[+1] Airplane Simulator (Airsim-3)[+1]: http://tinyurl.com/28zee8ky Alien Clonepure[no-entry-sign]: https://archive.org/download/alienclonepure(Mockingboard music should appear during gameplay, not the intro, but I couldn't hear it.) Angry Birds†[+1] Apple Cider Spider ...
[Image: docs.google.com] docs.google.com
docs.google.com [View]
azure78
Nov 5, 2025 - #4
Thanks JDW for the great review. I have one question for those that have one and use a A2CDVI v2.5 or similar with audio out ... does the Mockingboard audio happen to also come out of the DB15/Composite/RGB port on the back of the Apple IIc? Cheers
azure78
Nov 5, 2025 - #5
>> azure78 said:
Thanks JDW for the great review. I have one question for those that have one and use a A2CDVI v2.5 or similar with audio out ... does the Mockingboard audio happen to also come out of the DB15/Composite/RGB port on the back of the Apple IIc? Cheers Click to expand...
Ok ... answered my own question. No it doesn't. Wonder if there's an easy way to route it ...
Nov 7, 2025 - #6
>> azure78 said:
Wonder if there's an easy way to route it ... Click to expand...
I know Jonathan Adar (member of the Apple II Enthusiasts group on FaceBook) has done it.
6502Retro
Nov 7, 2025 - #7
I know Jonathan Adar (member of the Apple II Enthusiasts group on FaceBook) has done it. Click to expand...
@JDW I am now here on Tinkerdifferent. If i read the question I am not sure if @azure78 is asking if there is an easy way to route the analog stereo signal from mockingboard to A2CDVI or just to a header out of the back of the machine. If it is the latter, then yes I have done that and can post pictures.
azure78
Nov 7, 2025 - #8
Thanks for the responses! I was wondering about route to the A2CDVI through the audio line out (pin 5, 1VSOUND) of the DB15 Video port (when referencing the Apple IIc 4100 schematics). Understand this would need careful coupling, but would make a very clean solution in terms of getting mockingboard sound/video over to a hdmi?
Mackid
Nov 7, 2025 - #9
You might be able to combine the Aux_out lines with the 1V IIc audio line and make it work. The combined signal needs to be 1Vpp. But possible you might fry something too. A coupler like this could be used for a PoC. Sound would be mono though. (Mike Neil)
azure78
Nov 8, 2025 - #10
>> Mackid said:
You might be able to combine the Aux_out lines with the 1V IIc audio line and make it work. The combined signal needs to be 1Vpp. But possible you might fry something too. A coupler like this could be used for a PoC. Sound would be mono though. (Mike Neil) https://a.co/d/ckJypqD Click to expand...
Thanks! Using a coupler like that is a good way to prototype something. I have a spare IIc board I can work with, so going to need to brush up my oscilloscope skills ...
azure78
Nov 8, 2025 - #11
>> 6502Retro said:
@JDW I am now here on Tinkerdifferent. If i read the question I am not sure if @azure78 is asking if there is an easy way to route the analog stereo signal from mockingboard to A2CDVI or just to a header out of the back of the machine. If it is the latter, then yes I have done that and can post pictures. Click to expand...
Yes, it would be wonderful to see pics on where you created a header out the back.
