Recommended NeXTStation maintenance
Nov 4, 2021 - #1
I have a NeXT station I've had since college that I turn on occasionally. The hard drive started acting up a while back and I replaced it with a SCSI2SD. Other than that, it's still original. The display is a little dim, but still work.
Should I recap it. Replace the battery holder with a CR2032 holder? Anything I can do for monitor?
Any recommended guides would be great, including cap lists is helpful for someone like me with no background in this stuff!
Liked by KingDingus
pfuentes69
Nov 8, 2021 - #2
It I was so lucky to be the owner, I'd definitely check the caps for signs of leaks or corrosion nearby... and once I took out the board I'd give a good clean with IPA.
I personally don't like the CR2032 mod... but I hope you already replaced the battery.
reallyrandy
New Jersey
Nov 12, 2021 - #3
>> pfuentes69 said:
I personally don't like the CR2032 mod... but I hope you already replaced the battery. Click to expand...
Can you elaborate regarding why you don't care for the CR2032 mod? I was thinking of going that route with the kitty adapters. Or is that even what you were referring to?
pfuentes69
Nov 12, 2021 - #4
>> reallyrandy said:
Can you elaborate regarding why you don't care for the CR2032 mod? I was thinking of going that route with the kitty adapters. Or is that even what you were referring to? Click to expand...
It's just because I don't like much changes that affect to the aesthetics.
But from a practical standpoint the CR mod is a very good idea.
Nov 12, 2021 - #5
Yeah, the little adapters that allow you to put a CR2032 battery in the existing PRAM battery slot would be ideal, because it's not modifying the board, but giving you the same benefit of not worrying about battery leakage (https://www.etsy.com/listing/103410...aa-battery-replacement?ref=shop_home_active_1).
Liked by KingDingusandpfuentes69
pfuentes69
Nov 12, 2021 - #6
>> wottle said:
Yeah, the little adapters that allow you to put a CR2032 battery in the existing PRAM battery slot would be ideal, because it's not modifying the board, but giving you the same benefit of not worrying about battery leakage ( https://www.etsy.com/listing/103410...aa-battery-replacement?ref=shop_home_active_1 ). Click to expand...
Yes, that's ideal. Best of both worlds... I didn't know about this "kitty" thing, so I though this was about soldering a CR battery holder, which is what I don't like...
I need to get a couple of these adapters...
Nov 12, 2021 - #7
>> pfuentes69 said:
Yes, that's ideal. Best of both worlds... I didn't know about this "kitty" thing, so I though this was about soldering a CR battery holder, which is what I don't like... I need to get a couple of these adapters... Click to expand...
I don't think these particular adapters will work - the size and type of the NeXT battery is different than the 1/2 AA you get in Macs. Pretty sure it's this one. I'd have to go pull one of mine to double check, but I'm 99% sure this is it:
BR-2/3A Panasonic - BSG | Battery Products | DigiKey
Order today, ships today. BR-2/3A - 2/3A Lithium Poly-Carbon Monofluoride 3 V Battery Non-Rechargeable (Primary) from Panasonic - BSG. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
[Image: www.digikey.com] www.digikey.com
Also, linkage from nextcomputers.com
NeXT Lithium Battery
www.nextcomputers.org
www.digikey.com [View]
www.nextcomputers.org [View]
JdM74
Georgetown TX
Mar 5, 2024 - #8
Definitely recap your NeXTstation. There is a comprehensive guide on what's needed to do the job. If you have soldering skills, it can take a couple of hours, but certainly worth it. I just got done recapping a Mono and Mono Turbo slab and a Cube logic board. Happy that they're done.
Slab recap guide: http://www.asterontech.com/Asterontech/nextstation_mono_retore.htm
As for batteries..I say go with the original. The Panasonic battery that's in there is one of the best made, and will last close to 30 years without any failures.
