| PowerMac G3 Blue and White Chime no video now no chime |
KHEMISANTOS New Tinkerer -------- Joined: Oct 12, 2022 Posts: 16 Likes: 13 |
Sep 23, 2023 - #1
Hi all,
have a powermac g3 blue and white 450MHz DVD. It's been sitting since I moved decided to get back into the hobby. It did boot into OS 9 when right before I moved it's been sitting for about 2 yrs. It chimed no display switched displayed just to be sure. Still chimed popped the open side pervious me removed the pram battery grab one that says it's good. Chimed removed all ram except one stick chime no video. Switched ram stick same issue. Reseated video card no chime now no keyboard response. Pulled pram battery no chime. Any thoughts on next steps? also could I be using the wrong pram battery I put in a tadiran tl 5151 |
eric Administrator MN -------- Joined: Sep 2, 2021 Posts: 1,152 Likes: 1,936 |
Sep 23, 2023 - #2
I'd just remove the battery - no need to add a bomb that could go off once you forget about it.
Easy things to try: Push the reset button on the motherboard Reset the PRAM (even if it's been sitting without a battery) Remove and re-seat the video card Remove any other PCI cards Disconnect the HDD Keep trying to narrow down the component that may be causing the issue. Liked by KHEMISANTOS |
Sep 23, 2023 - #3
I was curious about the Pram battery as I remember some pre g3 beiges won't boot or have issues of battery is dead or not providing power. Vaguely remember an issue with a 6100 want sure I'd the G3 B&W would act odd without one |
Sep 23, 2023 - #4
Did you try resetting the pram? Option, Command, P, and R keys right after power - even without video. Keep holding them down and let it chime 4-5 times and see if that resolves it.
Sep 23, 2023 - #5
Sep 23, 2023 - #6
In case anyone is wondering took the DVD decoder off the graphics card and reseated still doesn't chime but boots. Guess it got shifted around in the move go figure.
Liked by Certificate of Excellence |
