PowerMac 8100 Booting issues
nottomhanks
Apr 26, 2022 - #1
Hello there!
I just picked up an 8100/100, and it chimes when you boot, (actually it powers up when you plug the IEC cable in, which is interesting).
Do you have to have the HPV video connector to see video, or will it jump to the next available video card?
I tried resetting the PRAM, but it wouldn't work.
Please help if you can.
Craig
RetroTheory
Apr 26, 2022 - #2
Have you tried resetting after powerup?
if the battery is flat or not present you just get black screen after bong, so the reset is necessary if the machine was off for a length of time.
See here:
Liked by Mr. FahrenheitandAlf Torp
Mr. Fahrenheit
Apr 26, 2022 - #3
The 6100, 7100, and 8100 series require a good PRAM battery on-board to display any video.
The instant power-on you experienced could be the power button on the rear rotated into the "always on" position.
nottomhanks
Apr 27, 2022 - #4
Ah. Those are helpful tips. Will the video show up on the DB 15 connectors on the Nubus Video card, or will it try to go to the HPV first??
RetroTheory
Apr 27, 2022 - #5
The mac has sense pins on its monitor connections, it knows there is nothing there so will initialise nubus if monitors is connected there. HPV is not required.
Liked by nottomhanks
JustG
California
Apr 27, 2022 - #6
I may be incorrect but I remember reading somewhere that 7100 and 8100 systems need to have a card in the PDS slot otherwise the computer may not boot or can crash.
Liked by RetroTheory
RetroTheory
Apr 27, 2022 - #7
You are quite right, That's what it says in the Service source, i have not encountered an issue in real live though. Currently running my 8100/100 without a video card or terminator, that the link above shows my one going to flashing floppy as such.
nottomhanks
Apr 28, 2022 - #8
The weird thing about this machine is that the bezel says 8100/100 but the logic board says "Flagship 110 Mhz". Plus it has the NewerTech G3/300 card installed. Is this a rare logic board or something?
bakkus
Apr 28, 2022 - #9
>> nottomhanks said:
The weird thing about this machine is that the bezel says 8100/100 but the logic board says "Flagship 110 Mhz". Plus it has the NewerTech G3/300 card installed. Is this a rare logic board or something? Click to expand...
The NewerTech is a cool addon, but could be one source of issues.
Did you try booting with the G3 removed?
There was a 110MHz model released late 1994.
nottomhanks
May 24, 2024 - #10
Just following up on this TWO YEARS LATER. I had my friend @ComputerCompulsive take a look at this over the past few weeks, and he figured out that the L2 Cache was bad, and it wouldn't post if it was installed. He removed it, and then got it to boot. I was over there this morning and we did some extensive testing with two logic boards, two G3 accelerators, AND two HPV cards!! Will post YouTube links soon.
Liked by ComputerCompulsive
nottomhanks
May 24, 2024 - #11
Here's the YouTube link for my Vintage Apple playlist: https://www.youtube.com/playlist?list=PLhOaaWxH4GkL78Jo7LwMmcHz047Fd6NL3
Liked by Elemenoh
ComputerCompulsive
May 24, 2024 - #12
>> nottomhanks said:
Just following up on this TWO YEARS LATER. I had my friend @ComputerCompulsive take a look at this over the past few weeks, and he figured out that the L2 Cache was bad, and it wouldn't post if it was installed. He removed it, and then got it to boot. I was over there this morning and we did some extensive testing with two logic boards, two G3 accelerators, AND two HPV cards!! Will post YouTube links soon. Click to expand...
I did a recap too ;) should be good for a while
