Macintosh Quadra 700 Expansion Slot Covers
RetroMagic
Jun 29, 2024 - #1
Hi, everyone! :) I'm new to the site and didn't find anything related to this (sorry if someone already posted something similar).
Anyway, I recently purchased a Macintosh Quadra 700. It lacks rear covers on the two expansion slots. I was wondering if I should find replacements or something to cover those for thermal/airflow reasons.
Most of my experience with retro tech has been in 90s PCs but I've always found Macs and other eras of computers to be really fascinating so I'm venturing outside of my comfort zone. I've always read that PCs of the 80s/90s relied on the expansion slots (and any other intended case covers) to be intact so enough air flowed over the chips to passively cool them. I'm not sure how hot the Quadra 700 gets and it only has the PSU fan and a heat sink on what I think is the processor. I don't want to inadvertently cook the poor thing.
Jun 29, 2024 - #2
The '040 can get a bit toasty as they were the original 800nm mask versions - but still doesn't need a fan at stock speeds - the fan in the PSU keeps a steady, quiet flow of air through it.
You're not going to wreck anything by not having anything in the expansion slots, or by not having an expansion slot cover - if you did want to put something in there, well if you have a BlueSCSI, you can print one of these out designed by Mr Lurch (from Youtube fame)
Macintosh IIci Rear panel SD Card bracket by MrLurch
I need a rear IIci bracket to mount and externally facing SD Card, so I took the holder bit from Colins LC PDS one and adapted it to fir a IIci
[Image: www.thingiverse.com] www.thingiverse.com
www.thingiverse.com [View]
RetroMagic
Jun 30, 2024 - #3
The '040 can get a bit toasty as they were the original 800nm mask versions - but still doesn't need a fan at stock speeds - the fan in the PSU keeps a steady, quiet flow of air through it. You're not going to wreck anything by not having anything in the expansion slots, or by not having an expansion slot cover - if you did want to put something in there, well if you have a BlueSCSI, you can print one of these out designed by Mr Lurch (from Youtube fame) Macintosh IIci Rear panel SD Card bracket by MrLurch I need a rear IIci bracket to mount and externally facing SD Card, so I took the holder bit from Colins LC PDS one and adapted it to fir a IIci www.thingiverse.com Click to expand...
Thank you for the advice and neat idea suggestion!! I can rest at ease now :)
