Mac SE30 VLSI chip replacement
darvil
Apr 17, 2025 - #1
Hello! Recently I tried to turn on my Mac SE30 and got hit with a bad surprise... Monitor failing to turn on, raster of horizontal lines, and other errors. Took the board apart, and found this VLSI VC2982-0002 chip with a crack:
It may be hard to see, but there's definitely a crack (you can feel it with the finger). I must guess this is what is causing these weird issues.
I am afraid this could have been caused by a faulty power supply giving the wrong voltages, thus I am going to check that first before plugging it on again.
I am also taking this chance to recap the last two axial capacitors that I did not replace at the time.
About this chip... How easy is it to find a replacement? Also, if you have any information to share about it, please do! I'm interested into knowing what it's purpose is. Thanks!
1744890488686.png [View]
_nec6678
Apr 17, 2025 - #2
I looked up the chip, and found some potential replacements (only one digit missing) which I'll link to here, and another one that is listed as "high quality second hand" here. Unfortunately, according to this forum, this chip is likely responsible for the floppy drive. Maybe try looking for loose connections to the solder pads in other chips: I was able to stop a high pitched noise coming from the speaker in my LC II with corrosion on the board by pressing down and wiggling one of the chips!
darvil
Apr 17, 2025 - #3
>> _nec6678 said:
I looked up the chip, and found some potential replacements (only one digit missing) which I'll link to here , and another one that is listed as "high quality second hand" here . Unfortunately, according to this forum , this chip is likely responsible for the floppy drive. Maybe try looking for loose connections to the solder pads in other chips: I was able to stop a high pitched noise coming from the speaker in my LC II with corrosion on the board by pressing down and wiggling one of the chips! Click to expand...
That is really interesting. I'll keep taking a look around then. Also I'm noting those links down. Thanks!
Liked by _nec6678
repeatloader
Jun 10, 2025 - #4
The chip is for the floppy, however... on my macintosh lc, i was having boot issues and video issues even... then i pressed down on that chip and it would boot normally. It was a broken solder joint on the chip
darvil
Oct 24, 2025 - #5
Hello again! It has been a while since I wrote this, but I am happy to say I was able to fix it.
I replaced the rest of the capacitors on the logic board and that didn't seem to fully fix it. I realized that sometimes the vertical deflection collapsed occasionally, among other logic errors like failures when booting up. I quickly realized the issue could be related to funky solder joints on the analog board, specially the motherboard cable connections.
After reflowing all the contacts on the analog board, it started working again! Turned out to be simpler than I initially thought...
It looks like after all the issue wasn't caused by the chip, although I will see if I get any issues when attempting to fix the floppy drive.
Thanks!
Liked by iantm,bakkus,_nec6678and 1 other person
