Mac mini G4 running Mac OS 9.2
Forums > Vintage Apple > Macintosh > PowerPC G3, G4 & G5 (New World ROM) > Mac Mini G4
pfuentes69
Mar 5, 2022 - #1
Hi,
this section is a bit empty, so I will show off my new Mac mini G4 1.5Ghz that I got for cheap, mostly with the objective of having something small to run Mac OS 9.
I used the Mac OS 9 Lives! setup for unsupported Macs.
It works like a charm, with the only issue of not having internal sound. Only works with external speakers and the quality is bad, but in theory can be solved with an USB sound adapter. I ordered one and hopefully will do its job.
Definitely this is a great machine to play some games and try stuff made for PowerPC, while I still prefer my good older 64K machines...
IMG_2163.jpeg [View]
IMG_2172.jpeg [View]
Liked by retr01,SteveHere,rikerjoeand 1 other person
KingDingus
Florida
Mar 5, 2022 - #2
Thank you for sharing. I've been picking these up cheaply from eBay because they are so easy to work on and don't take up much space in the office.
I've considered installing OS 9 to one of them to play Dues Ex.
Liked by pfuentes69
TheJ
Canuck-land
Mar 6, 2022 - #3
What fabulous timing !!
I'm doing the same thing! I recently eBayed two G4 Mac mini's and will setup one with OS 9.
One doesn't boot and the other is Password protected at the OpenFirmware level.
Anyone know how to unlock that?
J
Liked by KingDingus
pfuentes69
Mar 6, 2022 - #4
>> TheJ said:
What fabulous timing !! I'm doing the same thing! I recently eBayed two G4 Mac mini's and will setup one with OS 9. One doesn't boot and the other is Password protected at the OpenFirmware level. Anyone know how to unlock that? J Click to expand...
No idea... I just checked on Google to learn about it and I saw comments about adding or removing RAM to make the Cmd+P+R boot keys to work and being able to wipe the PRAM.
It would be nice to know how you sorted it out.
TheJ
Canuck-land
Mar 7, 2022 - #5
I opened up the Mini that wouldn't boot today. Surprise surprise... no RAM or HD.
I moved the RAM over from the other mini and installed a new 250GB SSD.
I prrtisioned the drive in 2 pieces; 100GB for OS 9 :cool:
Booted up the modded OS 9 CD and the installation went flawlessly :)
Spent a couple hours picking the "freshest fruits" from the Macintosh Garden.
Happy MARCHintosh !!
J
Liked by Certificate of Excellence,SteveHereandpfuentes69
KingDingus
Florida
Mar 16, 2022 - #6
47E9070E-5F2D-41CD-94B5-A92A7901FC7E.jpeg [View]
Liked by pfuentes69
TheJ
Canuck-land
Mar 16, 2022 - #7
Your timing is ridiculously awesome !! (Clearly we are in the "Retro Matrix" together or something!)
...and congrats on achieving "Classic" ;-)
I'm currently taking out the HD from the troublesome Mini in the hopes that doing so will allow me to finally zap the Parameter Ram.
Trying to zap the PRAM with and withour the RAM installed did not work on this mini. It did for the other one! Weird.
Oh well... I'll finish swapping the HD with an unformatted SSD and try again.
Liked by pfuentes69
TheJ
Canuck-land
Mar 16, 2022 - #8
Hmmm.... No dice.
I still can't get past the Open firmware password /lock.
KingDingus
Florida
Mar 16, 2022 - #9
The process was surprisingly easy. However, I had to make a late night run to Walmart to pick up some blank CD-RWs. My goal has been to play Deus Ex on a system running the original program on a native OS. With the maxed out RAM and SSD this is blistering fast and satisfying project.
pfuentes69
Mar 16, 2022 - #10
>> KingDingus said:
The process was surprisingly easy. However, I had to make a late night run to Walmart to pick up some blank CD-RWs. My goal has been to play Deus Ex on a system running the original program on a native OS. With the maxed out RAM and SSD this is blistering fast and satisfying project. Click to expand...
How's your audio working?
I have very bad audio only via the external jack.
pfuentes69
Mar 16, 2022 - #11
Well, seems I found a solution for the audio.
I received this today: https://www.aliexpress.com/item/4001111644497.html
The device is not appearing in the sound control panel, and it has some limitations, but it's working fine. I tried several games and the sound quality is pretty good.
KingDingus
Florida
Mar 16, 2022 - #12
According to the build information, the internal speaker will not work after the install.
Liked by pfuentes69
MrBicycle
Mar 4, 2025 - #13
>> TheJ said:
Hmmm.... No dice. I still can't get past the Open firmware password /lock. Click to expand...
A little late to the party but I was wondering if you ever unlocked the system?
Based on this posting, you would immediately press the PRAM reset keys after changing the memory configuration (not merely swapping from one slot to another but a different amount of memory).
So the firmware password reset wouldn't happen just by pressing the keys. Changing the installed memory amount apparently releases access to initiate that reset.
If you didn't PRAM reset directly when launching with that new config you wouldn't be able to reset PRAM on a second launch.
discussions.apple.com [View]
