| Looking to upgrade my G3's hard drive to a bigger one and need some basic advice |
bryanambition New Tinkerer London, UK -------- Joined: Oct 19, 2022 Posts: 18 Likes: 4 |
Dec 19, 2022 - #1
Hey all--I'm planning to replace my current G3 10GB internal hard drive to a larger one. The best (and most affordable) one I found was 500GB, and from what I understand the G3 can only tolerate partitions up to 128GB. So my question is: can I just install the new HD as-is, and expect the system to either partition it for me upon OS installation, or is there another step I should be aware of first?
Thanks so much for your time! ;-) |
Dec 19, 2022 - #2
Hi Bryan - welcome to TD!
What is your current G3? Is it a B&W model, or a beige? I'm guessing a B&W - if so - do you know what revision of ATA controller you have? |
Dec 19, 2022 - #3
Dec 19, 2022 - #4
Aaah, gotcha - if it's an iMac, then no need to worry about my question, it's only pertinent if it was a B&W G3 tower.
As long as the drive is partitioned into multiple smaller volumes, you should be okay - it should recognise the drive as-is, but make the partitions 127GB or less each as that's the max addressable size. |
Dec 19, 2022 - #5
Certificate of Excellence Active Tinkerer United Sates -------- Joined: Nov 1, 2021 Posts: 766 Likes: 531 |
Dec 20, 2022 - #6
I'd boot into the installer CD & partition before installing. Tiger would be a great choice as it introduces non destructive partitioning. Under utilities drop down from the install cd you'll find the partition tool disk utility that you can use to partition the new drive prior to OS installation. Another option would be to partition from an external enclosure or powerMac with empty drive sled.
Liked by bryanambition |
Dec 20, 2022 - #7
ScutBoy Administrator Northfield, MN USA -------- Joined: Sep 2, 2021 Posts: 356 Likes: 342 |
Dec 20, 2022 - #8
Dec 21, 2022 - #9
For slot loaders the limit is 128gb for boot and storage, for earlier trayloaders, storage is 128, boot is 8gb. This changed/increased when Apple disco'd the HeathrowATA controllers in the Trayloaders for KeylargoATA controllers in the slotloaders.
and no worries - only reason I recall this was getting educated by lightbulbfun over on MR. That guy is a wizard of PPC knowledge. So I guess the difference between ATA4 & 5 & bios implementation maybe? Hopefully someone with more knowledge can enlighten us? |
