iMac G3 Slot Load Optical Drive
MacEffects
Aug 10, 2024 - #1
I am looking to design a rebuild kit of rubber rollers and belts to be newly manufactured.
It would be really helpful if someone knows the pin out of these drives and if I can give the drive power only and make a switch to trigger eject for testing the new parts.
If anyone has details, it would be much appreciated!
Liked by dgveedubbus89,eric,Kai Robinsonand 1 other person
Francois
France
Aug 11, 2024 - #2
They may be the same model used in the G4 Cube, and in the Cube there is an interface board that convert the connection to standard Molex & IDE...
Aug 11, 2024 - #3
It should be a standard JAE connector it its using the adapter board.
