| Got wrong hard drive for my iMac G3--is there any hope? |
bryanambition New Tinkerer London, UK -------- Joined: Oct 19, 2022 Posts: 18 Likes: 4 |
Dec 21, 2022 - #1
As you can see by the attached image, I got the wrong type of hard drive for my iMac G3. I denoted which is old and which is new. Is there an adapter I can use to make the new one work? Or is it simply a different realm of hard drives altogether?
Also--while we're on the topic--can you tell me where I went wrong in choosing the incorrect new one? I did my research beforehand and looked for a 3.5 inch IDE hard drive. Thanks! ;-)
Certificate of Excellence Active Tinkerer United Sates -------- Joined: Nov 1, 2021 Posts: 765 Likes: 530 |
Dec 21, 2022 - #2
You want a 40pin pata/sata adapter with the Marvell 88sa8052 chipset. Most commonly folks order the red starTech units for best results. They're about $20 USD.
Dec 21, 2022 - #3
Hey thanks so much for the response! Super helpful, as always from this awesome place. Can I ask one more favour? I've found a few PATA/SATA adapters, but none that seem to have the right plug for the new hard drive. Would you be able to actually find a product and send me the link? Just so I can see what I've been doing wrong.
Thanks again! ;-) |
Dec 21, 2022 - #4
You're looking for something like this. Quite a few listings on eBay as well.
StarTech 40 pin pata to sata adapter. You plug the sata side into the hard drive and the ide ribbon cable plugs into the 40 pins pata connector on the opposite side. Connect molex power & set the adapter to master and you're off. Here's a nice vid by @Action Retro That illustrates the use of a sata/pata adapter to install a sata hard drive in an imacg3 tray loader, hurdles n all that he encountered along the way. OG ActionRetro at his finest :) |
Dec 22, 2022 - #5
Ahhh you and Action Retro to save the day! Thanks again so much you guys ;-)
Liked by Certificate of Excellence |
Dec 22, 2022 - #6
You could always request a replacement drive if it's a vendor error or use a pata/sata adapter. Either way a fun Christmas break repair/upgrade. [christmas-tree] |
