| G5 pro. Chime, no display |
Celotine New Tinkerer -------- Joined: Nov 28, 2024 Posts: 30 Likes: 10 |
Feb 14, 2025 - #1
Quick preface. I know exactly 2 things about Macs, jack and squat, and Jack left town. So here I am lol. I got this machine today. Got it cheap and has no peripherals. It chimes but put nothing to my monitor. It could be the monitor, cable or the graphics card. Anything else it might be? Something quirky about Macs, like not booting if the clock battery is dead?
Liked by Kai Robinson |
eric Administrator MN -------- Joined: Sep 2, 2021 Posts: 1,151 Likes: 1,935 |
Feb 14, 2025 - #2
Bad RAM can many times be a culprit - Try disconnecting everything (drives, PCI cards except video) and pulling all the ram but 2 sticks in matching banks cycle through them. Battery is normally not required (or at least wasn't for mine, I only have one)
Liked by KingDingus |
phunguss Active Tinkerer Stillwater, MN -------- Joined: Dec 24, 2023 Posts: 513 Likes: 441 |
Feb 14, 2025 - #3
Try power up, hold down Command+Option+P+R and wait for 3 full chime loops. If you don't see any video life by then, release and hold down the option key for a good few minutes. What type of external video ports are on the video card?
Feb 14, 2025 - #4
Feb 14, 2025 - #5
Depending on the G5 model, there are also diagnostic LEDs on the logic board towards the front that could be helpful.
Feb 14, 2025 - #6
Feb 14, 2025 - #7
Liked by eric |
Feb 15, 2025 - #8
Feb 15, 2025 - #9
Here is an external reference shot with the optical drive door assembly on the outside of a G5 model so you can compare... The door slides downward. Look at the gap on the left green zone... you have to put an extended paperclip through the holes to push the eject button. Paperclip has to be inserted approximately 3/4 of an inch. You should be able to feel the bubble button. So you will be inserting the paperclip on the green zone on the right (above), choose one of these holes to feel around with the paperclip (below). You may have to angle up or down a bit to find the sweet spot. You are looking for the big square eject button, NOT the tiny pinhole to manually force an eject. Now, remember that the door slides downward, so as soon as you press that button, yank out your paperclip so the downward door does not jam and the cd fails to open.
Feb 15, 2025 - #10
Feb 15, 2025 - #11
Feb 15, 2025 - #12
Certificate of Excellence Active Tinkerer United Sates -------- Joined: Nov 1, 2021 Posts: 765 Likes: 530 |
Feb 15, 2025 - #13
Another way to think about it is when you are inside your powermac g5 with the fan removed, along the upper right hand corner of each ram slot, the slot will be numbered 1,2,3,4 etc. Stick the first matched pair of ram in the slots numbered one (there should be a single slot labeled 1 in each ram bank), slot 2 for the second matched pair etc. This is how you install ram into a Powermac g5. I hope this gets you up and running. Good luck. . . . . Oh I just realized you said "boards" in your previous post - as in memory riser cards possibly? The name of your thread is confusing as it has parts of two (internally) very different machines. How many cdrom slots are on the front of the mac? One slot will be a Powermac G5 (PowerPC) which correlates to my initial instruction above. Two slots will be Classic Mac Pro (Intel) which are different machines. To install ram into cMP, follow these instructions. Use this instruction to ensure your ram is correctly installed before moving forward. Good luck! :)
Liked by phungussanderic |
Feb 15, 2025 - #14
Liked by phungussandCertificate of Excellence |
Feb 15, 2025 - #15
I also did some recent testing with other PC cards, nothing formally compiled, but here is a quick list: 9500 GT 9600 GT GT 730 Quadro K600 Quadro K4200 RX 460 RX 560 RX 580 Those that require power will need either the special mini-mobo connectors or some sort of SATA/MOLEX adapters.
Feb 15, 2025 - #16
Ok, what cMP do you have exactly? You can figure this out on the sticker on the back of the mac below the PCIe card slots.
In relation to your ram, you want to make sure the sticks are equally sized pairs - so two 512mb for exmaple and NOT a 512mb and a 1gb as an installed pair. Your cMP accepts 512Mb, 1GB or 2GB FB-DIMMs. Check to make sure they are identical. Their spec is below: 667 MHz, FB-DIMMS 72-bit wide, 240-pin modules 36 devices maximum per DIMM Error-correcting code (ECC) If you are satisfied that your ram is correct and in good order, move forward.
Liked by phunguss |
Feb 15, 2025 - #17
Feb 15, 2025 - #18
Feb 24, 2025 - #19
Feb 24, 2025 - #20
Three questions:
1. Did you still get boot chimes for every variation of RAM swaps you did? 2. Did you still get boot chimes with every GPU you tried? 3. PCI slots 1 and 2 are x16 and 3 and 4 are x4. Did you try a GPU in a different slot? Maybe the bottom PCIe slot is damaged? |
| Page 1 of 2 | Next > | Last >> |
