| First official C64 in 36 years |
Forums > Vintage Commodore > 8-bit Micro's
muse Tinkerer Oz -------- Joined: Nov 3, 2025 Posts: 41 Likes: 30 |
Nov 19, 2025 - #21
Liked by Scorpio_ny,ClassicHasClassandJDW |
JDW Administrator Japan -------- Joined: Sep 2, 2021 Posts: 2,534 Likes: 1,981 |
Nov 19, 2025 - #22
I've read THE MANUAL for the ArcardR joystick I received, but I am not seeing any mention about what in the world this round piece of plastic is for, although the hole suggests it goes on the stick itself? I'm also curious as to why a "shorter shaft" was included:
Nov 19, 2025 - #23
Im still using an original Wico Command Control joystick which has leaf style switches, its an original from the 80s. I think the round flat piece is a substitute/alternative to the piece thats already on there, like on most arcade control panels. |
Nov 19, 2025 - #24
Yes shaft is a bit short for larger hands. I suspect the flat round piece would help. It is primarly used for dust protection
Nov 19, 2025 - #25
@muse
I was guessing that was the case, but if the use of the FLAT round plastic piece is going to make it better for big, fat-fingered hands, why don't they all ship that way? Is the DOME shaped plastic that's installed by default on there purely for aesthetics? Or does it enhance the joystick somehow? My questions may seem dumb to people in-the-know, but I am not a gamer AT ALL, and I know really nothing about joysticks, and I only bought it because I think that will be part of the C64 experience. The documentation is quite lacking, I must say. I didn't mind using the QR code, but I did really hope the answers would be there. |
Nov 19, 2025 - #26
Nov 19, 2025 - #27
Nov 19, 2025 - #28
Theres a rubber sleeve which comes with this product ( I'm not seeing it in your package though ) that fits over the shaft to prevent the cover from flapping up and down as you use it.
You have the option to install fhe flat dust cover in place of the domed one original already there. I dont think it makes much difference, its there mainly to keep dust out and provide a smooth surface for the shaft to move against, and I suppose for aesthetics as well. Liked by JDW |
Nov 19, 2025 - #29
Correct in that my joystick kit does NOT include the "rubber sleeve" that slides onto the shaft.
I found a YouTube video with a greed colored rubber sleeve on the shaft as shown below... Again, mine didn't include that at all. Not sure if that's good or bad, but the product page shown below shows a photo of exactly what I received (the bare naked metal shaft)...
Nov 19, 2025 - #30
I also prefer the flat dust cover that came with yours over the one placed on there. Try both and see which one feels better to you. Liked by JDW |
Nov 29, 2025 - #31
Liked by Scorpio_nyandmuse |
Nov 29, 2025 - #32
@JDW It looks tempting but I already have 3 original units. Maybe I should just bite the bullet and justify it by saying that the chips in my current units will die someday :)
Liked by JDWandphunguss |
Scorpio_ny New Tinkerer -------- Joined: Aug 8, 2024 Posts: 30 Likes: 22 |
Tuesday at 2:23 PM - #34
Congrats on getting one! I am so tempted in getting one, but I already have several original C64's that I have acquired and maintained.
Tuesday at 3:38 PM - #35
Liked by Volvo242GTandmuse |
Tuesday at 8:08 PM - #36
The C64 Ultimate uses Gateron Pro 3.0 switches, definitely not your Alps. The Alps found in Apple keyboards have a very distinct acoustic character when pressed. I'm convinced it comes from the higher grade plastics absorbing and shaping the sound, something I can clearly hear on my SE/30 and esepcially the Apple IIe.
The original C64 keyboards weren't mechanical at all. They used a Mitsumi hybrid switch.. a plunger that presses a conductive pad onto a membrane. I'd describe the feel as slightly mushy, with a sudden stop and a bit of spring bounce after release. Perfectly usable, but nowhere near as satisfying as typing on an Atari 800 or an Apple IIe keyboard. Membrane hybrid switches were common in low end computers of the day however, some early production Amiga keyboards did use cherry mx switches but quickly switched to Mitsumi or Samsung hybrid switches to cut costs. A lot of the people complaining about the "issues" probably never owned an original machine, there were many slight imperfections as a result of the injection moulding process. The gap before the function keys is completely normal. Case colours were inconsistent back in the day with some units leaned towards grey, others a deeper brown and varying shades. The biggest difference with the new cases is the texture.. they're finer, slightly rougher, and have a subtle reflective sheen under light. Personally, I'm very happy with mine. I bought it to replace my original case after the PCB and keyboard mounts started disintegrating and wouldnt hold together. The Retro Fuzion cases include brass screw inserts to prevent that problem from happening again. I don't have a C64 Ultimate yet, but I'm sure I'll end up with one eventually. Liked by JDW |
Tuesday at 8:18 PM - #37
Yeah, I broke down and pre-ordered a Founders Edition. I suppose it's part of the history now, and I do like that it's very self-contained.
Never enjoyed the 64's original keyboard, I agreed with people who called it "overinflated." I prefer the 128 keyboard, but then, I also just prefer the 128 overall. Liked by JDW |
Tuesday at 8:29 PM - #38
The breadbin design actually helps with typing because you have more space to anchor your wrists. The wedge cases made that harder IMO.
Wednesday at 12:20 AM - #39
I've been reading what other C64 Ultimate buyers have been saying, and apparently the Starlight and/or Founders edition(s) have a keyboard that flexes. Video here:
2,839 [cjk-unified-ideograp] | Even slight pressure causes the PCB to flex significantly | RafaĆ Bernard PiechockiEven slight pressure causes the PCB to flex significantly
[Image: www.facebook.com]
www.facebook.com
It's not clear why that is. Some people say it's because it's transparent, while the other say it's because the PCB is too thin. I asked a question in one of the Facebook groups why they didn't just make the PCB thicker, and only one guy replied by saying they want to make more profit, which doesn't seem correct to me because I've not seen any evidence they cut corners in order to enhance profits on the machine that I have. I have not seen corner cutting in any of the photos and videos I've seen of the other machines either. So that one guy who replied back to me was probably just a cynic spreading negative speculation. All I can say is that when typing in a normal way on my beige colored machine, I'm not noticing any keyboard flex under my fingers on my model, which I guess is nice. But again, I didn't use the C64 back in the day so I don't have that frame of reference.
Wednesday at 4:18 AM - #40
You read and hear all kinds of things on the Web, the c64 community can be quite toxic at times and theres definitely a lot of negativity and hate directed at Christian Simpson aka Perifractic. People are complaining that they are using DB9 pcb mount for joystick ports instead of the original plastic DE-9 Atari style, others complaints are the about the tansparent control plate vs original metal plate. We are lucky to have these things but people will always find something to whinge about.
I've heard about the keyboard flex, I think it's probably a detail they overlooked and will have to improve that in later revisions. Original keyboards had no flex at all, they were tough. Liked by JDW |
| << First | < Prev | Page 2 of 3 | Next > | Last >> |
