Dry lubricants for floppy drives
YMK
Dec 18, 2023 - #1
I've been using Hoppe's and Remington dry lubricants on floppy drives with good results.
It's a teflon powder suspended in a solvent that flashes off.
Being completely dry, it stays put, won't attract dust and doesn't have the drag of grease.
[Image: 1702865515988.jpeg]
I applied too much to the left drive, but it's harmless. The manual-inject drive nearly ejects the disk clear of the drive.
1702865515988.jpeg [View]
Liked by Certificate of ExcellenceandJDW
KennyPowers
Dec 18, 2023 - #2
I'll have to give that a try...I have a bunch of that Remington dry lube. Only used small amounts of white lithium grease on floppy drives before. I also have Hornady One-Shot that I use to clean and lube my reloader. It dries to a slick, non-tacky finish too, so it might work well.
Fizzbinn
Charlottesville, VA
Sep 29, 2024 - #3
My Mac 512k internal and external 400k floppy drives were totally locked up. The original grease in these totally turns to glue and I was not getting anywhere with IPA. This "Dry Lube" did the trick for me:
3-IN-ONE Lock Dry Lube
Loosen up with this premium lock lubricant, designed to unstick any lock you can't get open.
[Image: 3inone.com] 3inone.com
After manually working the mechanism with floppy a dozen times or so and cleaning up the now flowing old grease with cotton buds both drives are working great!
3inone.com [View]
3inone.com [View]
Liked by Certificate of ExcellenceandYMK
CodeProfessor
Ontario Canada
Jul 9, 2025 - #4
Interesting, I use WD-40 Specialist Dirt and Dust Resistant Dry Lube Spray for my locks (I know it says WD-40, but I believe that is just the brand name). I will have to look into if it is comparable to what you are using.
Thanks for sharing!
Jul 10, 2025 - #5
>> YMK said:
Being completely dry, it stays put... Click to expand...
I guess the question is, "for how long"?
We know how long the wet stuff stays on -- for decades until it hardens like a rock. Dry lube won't harden, and so long as it will truly stay in place for many years, it sounds like a great alternative to wet lubricants.
Liked by YMK
