| Cpu0 and cpu1 help needed. |
Cyclone740 Tinkerer -------- Joined: Oct 29, 2023 Posts: 120 Likes: 8 |
Jun 18, 2025 - #1
So I am kinda embarrassed to say that I have not marked the CPUs to identify which slot each one goes in. And I was wondering if someone could enlighten me to help me understand what would happen if I put them in the opposite slots? How do I tell if I have them in the right slots, or is there no issues at all?
phunguss Active Tinkerer Stillwater, MN -------- Joined: Dec 24, 2023 Posts: 511 Likes: 440 |
Jun 18, 2025 - #2
Should be no issue at all. There are instances where if you have a single dead or faulty CPU, the computer will only work if the dead CPU is in one specific slot, so if you get no boot at all, swap them to the opposite positions. Run the Apple Hardware Test disk if you have issues.
Liked by Cyclone740 |
Jun 18, 2025 - #3
Jun 18, 2025 - #4
Otherwise try the Macintosh Repository here. I don't recall if the G5 can boot it from USB or not, I think I burned the CD. Liked by Cyclone740 |
Jun 18, 2025 - #5
Again thank you for all your help, I am just hoping that I can get the LCS back together properly, as there doesn't seem to be any guide or instructions about doing it, with my version and from as far as I had to go. |
Jun 19, 2025 - #6
Jun 19, 2025 - #7
Also do you know of anyone who has taken apart their dual pump LCS fully and then rebuilt it? I am just a little bit nervous about mucking up as I dont want to miss any screws or put them in the wrong places, and I want everything to go back together properly. Any advice with that would be a great help. Thank you again. |
Jun 19, 2025 - #8
I know there are at least 3 different versions of the LCS. Some single pump, some dual.
Jun 20, 2025 - #9
Now I have a really insane question, if I do the plumbing right, could I run my system using only one pump? Yes one of them just burnt the PCB and died on me. |
joevt Tinkerer -------- Joined: Mar 5, 2023 Posts: 218 Likes: 85 |
Jun 20, 2025 - #10
MacRumors has a couple recent threads on converting a Quad G5 to air cooling.
Jun 21, 2025 - #11
Jun 21, 2025 - #12
I linked some air cooling threads at #9 |
