| Color LCD Retrofit Kit for SE/30 by ZigZagJoe |
Dave928 Tinkerer Seattle, USA -------- Joined: Sep 17, 2024 Posts: 45 Likes: 33 |
Oct 8, 2025 - #21
yeah adding the pot to the zzj analog board is a PITA. i'll probly just hot glue mine into the hole. i wont ever really need it.
JDW Administrator Japan -------- Joined: Sep 2, 2021 Posts: 2,534 Likes: 1,982 |
Oct 8, 2025 - #22
The LCD is the perfect brightness for a normal lit room during the day. But when you stay up in the wee hours of the night, especially if you have bedroom light dimming like I do, being able to dim your LCD is important. Perhaps one of the biggest uses I get out of the brightness knob is when I need to start a multi-hour MacBench session just before I go to sleep, and I want to keep the brightness down low (but not off), so I can check the display now and then but not be prevented from sleeping due to an overly bright screen. |
Oct 8, 2025 - #23
Okay, friends. You can now install a BRIGHTNESS KNOB onto your LCD Color Kit....
Liked by cluster_fsck,joethezombieandDave928 |
cluster_fsck New Tinkerer -------- Joined: Oct 9, 2022 Posts: 14 Likes: 8 |
Oct 22, 2025 - #24
This kit is amazing and I need to get one. Would it be possible to control the screen's brightness through software? I need to dive into the kit's BOM...I wonder if it'd be possible to mimic a PowerBook screen to MacOS and use the Brightness control panel, or write a replacement.
zigzagjoe Tinkerer -------- Joined: Sep 10, 2024 Posts: 19 Likes: 31 |
Oct 22, 2025 - #25
David Cook Tinkerer -------- Joined: Jul 20, 2023 Posts: 130 Likes: 172 |
Oct 22, 2025 - #26
What about ADB instead? Solder to the internal pads. Include a temperature monitor, fan controller, and brightness control. Edit: Additionally, this would work on any ADB Mac. And, other kits can be added to the ADB chain. Liked by JDW |
Nov 8, 2025 - #27
I got one these kits and installed it last weekend - it's awesome. Everything fit perfect and the color board stacks right on the Asante MacCon pass-through connector and works like a charm. It's definitely a transformative experience to use my SE/30 this way - I never had a compact color Mac. Can't recommend this kit more highly!
Liked by ESM-NLandJDW |
| << First | < Prev | Page 2 of 2 |
