| Color CRT that fits in Macintosh SE FDHD? |
jmacz Tinkerer -------- Joined: Mar 21, 2025 Posts: 86 Likes: 95 |
Oct 22, 2025 - #21
I tried this for a 16" Macintosh Color Display and I got scratches / rub marks on the acrylic from the screen during forming. I ended up building a jig to bend the 5mm thick acrylic I was using. This was to put a 15" LCD panel inside the 16" Macintosh Color Display housing. This reminds me. I need to open this monitor up at some point and replace the 15" Samsung LCD inside. It's acting up. I was going to replace it with one of my 15" NEC 52V LCD panels (1024x768 resolution). I've been driving this monitor with a SuperMac accelerated video card for a super crisp 1024x768 output. The only issue with doing this LCD with acrylic in front hack is if you have OCD like me, it's super annoying putting things together without getting dust between the acrylic and the LCD panel. I don't have a clean room so it was clean, install, deinstall, clean, install, deinstall, until I finally got it as dust free as possible (after like a dozen attempts). Painful. No, doing it in a shower stall with hot water mist didn't help / wasn't easy. I have a home made laminar flow hood but not big enough for this monitor.
JDW Administrator Japan -------- Joined: Sep 2, 2021 Posts: 2,536 Likes: 1,984 |
Oct 22, 2025 - #22
Oct 22, 2025 - #23
Liked by jmacz |
Mk.558 Tinkerer -------- Joined: Nov 11, 2023 Posts: 112 Likes: 45 |
Oct 23, 2025 - #24
Oh of course. I've used System 6 on a 512Ke, and I wou...wouldn't recommend it. It's not slow, but it's not as fast as S3.3/F5.4, and you notice the memory is less than it was before. Since you have a 128K, have you tried doing a 128Ke? I am curious about whether EasyShare would work on such a thing. If you need a disk to test, I can make an image for you to burn -- you're probably a busy man. |
Oct 23, 2025 - #25
Yes, I have the ROM-inator (128K ROMs) in my Fat Mac Switcher equipped Mac512, but how is EasyShare used?
Oct 23, 2025 - #26
That is, assuming you have a 128K mac, not a 128K ROM mac. The 128K should have the 64K ROMs yes? Suppose you swapped in the 128K ROMs into a 128K Mac? |
Oct 23, 2025 - #27
It's a 512K Mac with Kay Koba's Fat Mac Switcher and also his ROM-inator I. The short summaries of those 2 videos are:
1. Fat Mac Switcher: Allows selection of 512K or 128K RAM (while Mac is OFF). 2. ROM-inator I: Allows you to flash the stock 128K ROMs, 64K ROMs, or customized ROMs. I currently use the ROM-inator I with 128K ROMs flashed so I can take better advantage of the 800K drive I have installed in that machine. I also have a HyperDrive Mac512 doesn't have the ROM-inator or Fat Mac Switcher, but it has a fixed 512K RAM. Can't remember if it has the 64K ROMs, but I think it does. Even so, you are mentioning the need for a 64K ROM, 128K Mac. My ROM-inator I Mac512 should allow that 64K ROM configuration. I just need to flash the 64K ROM. Three are certain "gotchas" though. |
<< First |
< Prev |
Page 2 of 2
[Print View] |
