BlueSCSI v2: Sluggish Performance on SE/30
Jun 19, 2024 - #21
@joopmac Are these instructions correct? (I've adapted them from your text above) https://github.com/BlueSCSI/BlueSCSI-v2/wiki/Image-File-Fragmentation#mac-os
joopmac
Jun 19, 2024 - #22
Should be fine - i did not enter the command " defaults write com.apple.desktopservices DSDontWriteUSBStores -bool true" though
Might be benificial though - would be most effective when done before the formatting, then the .ds_store will never be made =)
I think it's most important that its added to Spotlight exclusion list directly after formatting
And i also use command-shift-dot to delete all invisible files directly after formatting
so the order would be;
1: write defaults command
2: format SD
3: add to spotlight exclusion list in system prefs
4: command-shift-dot to view invisibles and delete them
5: copy files, once at a time. i have to admit did not try all at once yet, perhaps this even works now. i do not know
6: enjoy speed =)
Jun 21, 2024 - #23
>> joopmac said:
Erasing the SD, removing all the invisible files and then adding the SD Card to "Spotlight privacy" list, Then copying the files one by one gives perfect results... removing the invisibles and adding to spotlight privacy list in System settings is the fix Click to expand...
I've not had time lately to fiddle, but I believe I tried that before and found hidden files were still being copied. What I can say is my experience on Apple Silicon is totally different than when using an Intel Mac. Basically, I cannot create a usable SD card on Apple Silicon. I am forced to use an Intel Mac.
Are you using an Intel Mac or Apple Silicon? If Apple Silicon, what processor? (Mine is an M1 Max CPU.)
>> joopmac said:
keep up the good work, watched a lot of your videos and they are amazing, and educational Click to expand...
Thank you for your kind words. Sorry for being absent on YouTube much of this year. Finding a new place to live, then boxing your whole life, moving and unboxing has eating up all my free time. We're moved now, but still have much to do around the house and outside. Eventually, I'll get back into the YouTube game.
joopmac
Jun 21, 2024 - #24
Curious if if will work for you also, James
I tried it on arm64/Apple Silicon =)
