BlueSCSI v2 Bracket / Bezel
lundpk
New Ulm, MN
Sep 27, 2025 - #1
I have my first retro Mac project underway. Its a Power Macintosh 7600 and have a BlueSCSI v2 coming. Is there a 3D printable bracket that I can use to connect to the plastic sled. Or do people used double sided tape as their solution. I saw a 3D printable bezel and wondered if the alignment rquires a bracket.
Sep 27, 2025 - #2
This is probably what your looking for https://www.thingiverse.com/thing:6261300 or https://www.thingiverse.com/thing:6367789
If you don't have a zip drive in your 7600 you can use something like this to have access to the SD card from the front https://www.printables.com/model/636613-35-inch-bezel-for-power-macintosh-7000-series-and
Remember the 7600 has a 10MB/sec bus internally so make sure you hook the BlueSCSI up to that for the best performance.
And hello fellow MN'er :)
Liked by phunguss
lundpk
New Ulm, MN
Sep 27, 2025 - #3
Thanks phunguss.
