| 120GB SSDs in G4 Cube |
Forums > Vintage Apple > Macintosh > PowerPC G3, G4 & G5 (New World ROM) > PowerMac G4, iMac G4 & eMac
JDW Administrator Japan -------- Joined: Sep 2, 2021 Posts: 2,535 Likes: 1,982 |
Nov 30, 2024 - #81
I have to admit, I got burned out after my earlier failure with something that was supposed to work but didn't. I'll probably give it another shot when at least two or three more people have used the same method (either that from @Scorpio_ny or that from @jasperman . Right now, the stock spinner drive in one of my Cubes is still working. The other is dead and so I can't use that other Cube as a result, but that's OK for now. The OWC looks like the most appealing solution to my eyes, but my experience with past OWC SSD purchases have been mixed, which is why I'd like to see a few other Cube owners give it a shot and report their experiences.
I am happy to see these solutions being explored though. The Cube is one of the best PPC machines, in my opinion due to the great industrial design. Both of my Cubes are accelerated, making them very usable with software made for the G4 chip. |
Francois Tinkerer France -------- Joined: Aug 9, 2022 Posts: 116 Likes: 51 |
Nov 30, 2024 - #82
Or just buy an IDE SSD, they're expensive, but maybe less than trying a whole bunch of adapters?
jasperman New Tinkerer -------- Joined: Nov 9, 2024 Posts: 12 Likes: 6 |
Nov 30, 2024 - #83
i don't believe there are any 3.5" IDE SSDs(???) so you will need a 3.5 to 2.5 adapter along with the 2.5 IDE. Liked by JDW |
phunguss Active Tinkerer Stillwater, MN -------- Joined: Dec 24, 2023 Posts: 513 Likes: 442 |
Nov 30, 2024 - #84
Nov 30, 2024 - #85
Nov 30, 2024 - #86
Nov 30, 2024 - #87
Nov 30, 2024 - #88
Looks like I used #10 for the optical drive plus an additional cable to convert the 7+15pin to 7+6pin Sata+Power. Slot load SATA dvd from an old iMac (unknown model). It is likely you could use an older slot load optical drive that has the ATAPI connector and find an IDE adapter with a master/slave jumper. This one does not have a master/slave jumper.
indibil New Tinkerer -------- Joined: Aug 6, 2025 Posts: 6 Likes: 6 |
Aug 6, 2025 - #89
Hi, I found this forum thanks to @JDW.
You've already provided many solutions, but I'll briefly share my experience. I have SSDs in all my G3 and G4 Macs, and I've used these adapters, all with JMicron. I've only had some incompatibility with the SATA or mSATA HDD used, but using another brand has worked for me. For 3.5" I use this one: https://es.aliexpress.com/item/2055...st_main.5.2e23194dH05Beq&gatewayAdapt=glo2esp And for 2.5" this one: https://es.aliexpress.com/item/1005...t_main.31.2e23194dH05Beq&gatewayAdapt=glo2esp https://es.aliexpress.com/item/1005...t_main.86.2e23194dH05Beq&gatewayAdapt=glo2esp They work on Pismo, Lombard, and Mac Mini G4. The 3.5" one also works for me on the Cube. Just a detail: this happens to me on all Macs that share an ATA connector and use Master/Slave. OSX Sorbet Leopard works without problems, but OS9 struggles to recognize the first partition, but it boots. First, the floppy disk appears, but after a few seconds, OS9 boots. This doesn't happen if there's no Master/Slave. I hope this helps. Liked by JDW |
| << First | < Prev | Page 5 of 5 |
